Grid Display
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2009-08-17 03:57 AM
Is it possible to turn off Grid Display globally instead of doing it in each view?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-08-17 04:11 AM
I've never notice this. But sometime it's automatically off in certain views.
Do you consider creating a template file with grid off for all ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-08-19 09:56 PM
Danj wrote:click View-Grid Display.
Quick question
Thanks
Is that what you mean?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-08-19 11:39 PM
If you are talking about just section or elevation views, you can select all these markers and as grid visibility is a common parameter open the settings box crtl/cmd+T and on the bottom tab uncheck that it is visible.
If you want this as a permanent change then don't forget to redefine the appropriate views.
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-08-20 01:34 PM
Yes, there is such a thing that the Construction Grid Settings can be unique for each Viewpoint.
So you can have Construction Grid Settings in a Setting different from those on the Floor Plan.
You can even have different Construction Grid Settings for each individual Section.
At least this is how it worked the last time I checked.
Sorry, you will have to set them one by one.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-08-20 02:21 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-08-20 05:46 PM
laszlonagy wrote:
I think he means the Construction Grid.
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-08-21 06:36 PM
Danj wrote:Turn its layer off in the associated layer combos. The only way for the plans.
Quick question
Thanks
Make sure that the grid dimensions are on the same layer.
If you don't want to do that, and need them off only in the S/E, select all the S/E (NOT the views, the actual viewpoints) and switch it off.
ArchiCAD since 4.55 ... 1995
HP Omen
