rob2218
Groin Vault morph object - how to show where it cuts?
see attached.
basically, I've created a brick groin vault object. Now...when i take a section cut...the part of the groin vault that is 'supposed' to show up in cut is...well, not showing as a cut. How/where/what/button will fix this?
I'm not all too keen on the "foreground" "background" cut overrides. it's all bit voodoo-BIM to me....very confusing sometimes how the foreground and background play a part in how objects show up in cut.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
2 Replies 2
If that structure is something with a constant thickness you could try to model it using the Shell Tool instead of the Morph Tool.
rob2218
Thanks, it does have constant thickness. I'll try it with the shell tool.
i>u
Edgewater, FL!
SOFTWARE VERSION:
