2005-01-13 10:27 AM
2005-01-14 03:30 PM
Ben wrote:Exactly that.
What Djordje meant ,Djordje please correct me if I'm wrong,was that you can mark elements just as you have done, but under window-->Palette Display, you will find at the bottom of the menu, Show Selections.
woodster wrote:Hmmm ... this is funny. Normally, not much of the building elements are saved in a template, BUT - ha! - now I see a reason: you should save section lines and details in the template, so therefore it is logical.
However, if you use the Find & Select feature (Edit/Find & Select...) you can save the Selection Set and it can be saved as a part of a Template as well. Funny, I would think that Selection Sets saved through the Find & Select... featured would show up in the Show Selections window? a wish?
2022-03-23 03:44 PM
Did you try to create an IfcZone using the IFC Manager, including the Zones (IfcSpace instances) you want to manage as a group? You could also do the same with IfcGroup, as a parent of IfcZone within the IFC Schema.
2022-03-23 03:48 PM
Just wanted to point out you have replied to a 17 year old post.
IFC wasn't even a thing then.
2022-03-23 04:03 PM
Hello, Barry
It was, not maybe within GS Archicad.
IFC 1.5.1. was publicly shown in a Frankfurt conference in 1996.
However, it is always nice to reply a 17 y.o. message 🙂
Btw, do you have a clue which was the date GS implemented the IFC add-on? From what I know it was developed by a third party. Any information?
Kind regards,
David
2022-03-23 04:13 PM
Actually IFC may well have been in Archicad back then.
I just checked version 12 (that was about 13/14 years ago?) and that has IFC.
It is an add-on but I think not 3rd party, it is included with Archicad.
2022-03-24 10:03 AM
It would be nice to know a bit of transparent history about this essential and core functionality within Graphisoft Archicad.
@Laszlo Nagy Some additional information?
2022-03-24 01:54 PM
Sorry, no, I don't know which version of Archicad IFC was introduced.
But I checked my materials, all the things I did for Graphisoft over the years, and I found an Interactive Training Guide I did for Graphisoft in 2007 for Archicad 11, and even then, there was a step of exporting IFC to be opened in Tekla Structures. I also found a PNG file with the name IFC_logo_AC10 from 2006. So, definitely, for at least 15 years, we had IFC in Archicad.
2022-03-24 02:09 PM
Hi, Laszlo
I knew that guide, indeed.
Interesting *.png! 🙂
We'll keep exploring
Thanks
David
