Steve Jepson
Grouping Zones
How can I group some zones together so I can move them around.
17 Replies 17
Djordje
Ben wrote:
What Djordje meant ,Djordje please correct me if I'm wrong,was that you can mark elements just as you have done, but under window-->Palette Display, you will find at the bottom of the menu, Show Selections.
Exactly that.
woodster wrote:
However, if you use the Find & Select feature (Edit/Find & Select...) you can save the Selection Set and it can be saved as a part of a Template as well. Funny, I would think that Selection Sets saved through the Find & Select... featured would show up in the Show Selections window? a wish?
Hmmm ... this is funny. Normally, not much of the building elements are saved in a template, BUT - ha! - now I see a reason: you should save section lines and details in the template, so therefore it is logical.
However, the other part has to be investigated yet!
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
davdelven
Did you try to create an IfcZone using the IFC Manager, including the Zones (IfcSpace instances) you want to manage as a group? You could also do the same with IfcGroup, as a parent of IfcZone within the IFC Schema.
David Delgado Vendrell
http://www.daviddelgado.cat
GIGABYTE AERO X16 16" AMD Ryzen AI 7 350 32GB 1TB SSD White Copilot+ RGB
Triple Monitor 16"+25"+32" Nvidia Geforce RTX 5060 8GB
SSD+HDD, Win11 Home - 64 ENG
AC18-AC28 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
I decided to not switch to the Subscription path, and stay with AC28 proprietary license. We'll see what the future brings us...
Just wanted to point out you have replied to a 17 year old post.
IFC wasn't even a thing then.
davdelven
Hello, Barry
It was, not maybe within GS Archicad.
IFC 1.5.1. was publicly shown in a Frankfurt conference in 1996.
However, it is always nice to reply a 17 y.o. message 🙂
Btw, do you have a clue which was the date GS implemented the IFC add-on? From what I know it was developed by a third party. Any information?
Kind regards,
David
Actually IFC may well have been in Archicad back then.
I just checked version 12 (that was about 13/14 years ago?) and that has IFC.
It is an add-on but I think not 3rd party, it is included with Archicad.
davdelven
It would be nice to know a bit of transparent history about this essential and core functionality within Graphisoft Archicad.
@Laszlo Nagy  Some additional information?
Sorry, no, I don't know which version of Archicad IFC was introduced.
But I checked my materials, all the things I did for Graphisoft over the years, and I found an Interactive Training Guide I did for Graphisoft in 2007 for Archicad 11, and even then, there was a step of exporting IFC to be opened in Tekla Structures. I also found a PNG file with the name IFC_logo_AC10 from 2006. So, definitely, for at least 15 years, we had IFC in Archicad.
davdelven
Hi, Laszlo
I knew that guide, indeed.
Interesting *.png! 🙂
We'll keep exploring
Thanks
David
