HCTPBWIW? [Railing Tool]
Patrick M
Mentor
This tool continues to hit the wall on its limits in very basic conditions.
4 REPLIES 4
Guru
Are these part of the Rail Connection?
Wonder when rail arrays will be implimented... the wish no longer seems to exist...
it is a connection issue. I just had to kick it around 5-6x and it eventually cleaned up. this was done with a single rail, using a complex profile
Separated rails will clean up automatically.
I can't say I have tried with a single complex profile rail.
Guru
Ah, yeah, your issue stems from the (profile_height)cos(slope_angle) of your "rail" being longer than the gap between your posts. It creates a single fillet at the mid point, and that just so happens to extend beyond your post. If you extended the distance between the top of your stair and the corner you should notice that it will clean up properly.
Ling.
ps. Rail Arrays when?
pss. I cannot seem to find the wish...
Setup info provided by author
