2004-12-10 07:42 PM
2004-12-17 07:12 PM
bill wrote:Don't delete the sections and elevations, as well as the detail markers. You can always move them around to the proper place.
"Is there a way to import "View Sets" from another pln?"
couldn't you make a duplicate of the file with the view sets, delete everything and then merge your .pln
2004-12-17 10:01 PM
2004-12-20 08:07 PM
2004-12-21 01:55 AM
2004-12-21 06:56 AM
2004-12-21 08:30 AM
Jeff wrote:Sorry.
I appreciate the try Karl, but it had the same effect. After the skylight add-on was removed, the file opened up as usual but with out a skylight error, obviously. However, none of the objects are visible in either 2d or 3d, just like before. I "select all" and it says that there are 14 roofs, for example, but there are no hot spots or selection dots on the 2d screen.
I am at my wits end.Now I see why. Definitely call GS tech support and have them download the file if someone from GS hasn't yet read this thread and grabbed it.
You can download the file, "Hildner" (1.3mb) from the folder titled "Skylight Error" at: http://www.modernmagic.com/filesor in OS X Finder, Go | iDisk | Other User's Public Folder and enter 'modernmagic'
2004-12-21 10:15 PM
COLUMN 6806 { ",[Ôw" 13 18 "Electrical" 1 "Roof" 0 ***** 3'-9 1/2" 0.000° 0" 0" 0" ***** ***** "???" 13 "Brick Common " 1 "Brick Common " 0 0.000000 0.000000 0.000000 0.000000as opposed to this column placed (at a random spot) in a 'good' file:
COLUMN 37948 { "Ftg Isol-001" 1 23 "Columns" 0 "Main Level" 0 66'-8 5/8" 34'-2 17/32" 0.00° 6" 6" 0" 9' 0" " Walls Interior" 2 "Empty Fill" 2 "Patio Stone" 0 1.672255 0.000000 1.672255 0.063713
2004-12-21 11:07 PM
