HELP! ZONE PROBLEM :(
I draw a project by Archicad 10. Now i have to give it to an Autocad user.
When i save the project in dwg format zones converted to blocks with their hatches. When i explode them in Autocad zone names changes as " room name"
How can we export them correctly without their hatches ( solid fills) ?
Go to Design > Set Model View > Model View Options
Choose "Show Zone Stamp" and "No Background" (the latter setting will automatically turn on the former).
Save your settings as a "Model View Option Combination" to apply to the views you wish to publish to DWG.
Thank you friend. I think Archicad is the best for Architects.
Best wishes...
ogabson
