HOW TO ROTATE THE WALL
Have created a gym wall using both the slab and wall tools, now need to rotate it up to a 77• slant. Opened the library part, but can't figure out what to add, or what tool to use to rotate...I guess it is around the z axis?
6 REPLIES 6
Erich
Go to your 3D script and type
ROTx 77
at the top of the script window. In Archicad the Z axis is vertical so you will want to rotate about either the X or Y axis.
You may also want to see the overhead projection of the assembly in 2D. If so, go to your 2D script window comment out anything that might be there (I suspect that there is nothing and your 2D view is from the 2D symbol window) and type
PROJECT2 3, 270, 2
at the top of the script. This will have archiCAD produce an overhead projection of your rotated object.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Think it rotated up, but don't have a proper 2d view. Not sure what to "comment out" and what is "
"PROJECT2 3, 270, 2
Entered "PROJECT2 3, 270, 2" at the top of the 2d window, but nothing happened...
ROTx 77
PROJECT2 3, 270, 2
Re read your advice, performed all changes, but here is what the library part shows....is there a way to get the 2d overhead window to show a projected canted wall?
ROTx 77
PROJECT2 3, 270, 2
Here is what I learned about special canted wall objects today. THANK YOU TO ERICH... See the fancy gym wall in the distance?
ROTx 77
PROJECT2 3, 270, 2
Erich
I have been away for a bit. Did you get the 2D to work or are there still issues?
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
David Maudlin
Comment Out is the same as Uncomment, which adds an "!" in front of each line which prevents the line from being read as code (reads as a comment). This command can be added to your Work Environment for faster script changes. Uncomment serves the same purpose as deleting the code, without actually removing it.
Archimamamia wrote:
and what is "
"PROJECT2 3, 270, 2
The rest of the code should be deleted or Uncommented for this code to work properly. It is creating a 2D Symbol directly from the 3D code, which can easily show complex forms that would be hard to code in 2D, the downside is that it is more resource intensive, so should only be used in special cases, not as a standard solution. The command must be entered exactly, the extra " in your text will render it unintelligible.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
