Headroom as a boolean object?
Kamelite
Is it possible to use the headroom-figure to make a hole in a slab?
[attachment=0]headroom.png[/attachment]
Windows 10, Archicad 28
You could try it yourself: use the Solid Element Operations Palette and use the stair as Operator and the slab as Target, then you will see if it works. I I cannot try it myself, because I'm not at my computer at the moment.
Kamelite
I already did, but as i select the overhead-figure, I also select the stair. And doing a boolean operation just removes the footprint of the stair.
Just wondered if there were any clever tricks to accomplish the task.
Thanks anyway!
.Kamelite
