ā2006-05-04
03:49 AM
ā2023-05-26
03:08 PM
Rubia Torres
ā2006-05-04 04:34 AM
ā2006-05-04 07:53 AM
s2art wrote:Obviously, in fact, thats the first thing I did. I even tried turning all the layers on. And rest assured, I did not erase any layers at any time.
You've obviously checked that the appropriate layers are (or layer combination is) on, or even turned ALL layers on to see if your 2D stuff was not drawn on the wrong layer. Obviously.
ā2006-05-04 08:35 AM
ā2006-05-04 01:09 PM
ā2006-05-04 04:28 PM
ā2006-05-04 07:01 PM
Mike wrote:Hi Mike, my Sections and Elevations are Auto-rebuild. Then I add some dimensions, text, lines, and in some cases...hatches to improve the elevations and sections. Then as a quick way to go back to my elvations and/or sections, I save it as a view under "View Sets". (Please take note: I've already checked and made sure it wasn't a layer issue....so it has nothing to do with layers not showing or deleted layers).
Are your sections set as a drawing? Auto-rebuild model? If you are working on your sections as a drawing, you should out of habit cut all drawing elements and paste them back into the sect/elev window. This is a lame "feature" that graphisoft has implemented that keeps 2d elements linked to the model.
ā2006-05-04 11:24 PM
ā2006-05-04 11:38 PM
s2art wrote:Yes Stuart, I have zoomed to extents as well. And just to point out, I did not move my Section / Elevation markers.
Just to cover the obvious, you have zoomed to extents too? (Usually only an issue if Section / Elevation markers have been moved. Probably not the case here, but you have to cover all possibilities).
ā2006-05-05 12:13 AM
