Help! Some parts of my floor plan has dissappeared..
I can see all of my furniture and exterior walls in the 3d view and sections and elevations. However, on the floor plan I cannot see it. This happened all of a sudden, things were showing up on my floor plan fine, then I started to edit the exterior facing of my exterior walls and I looked closely and realized parts of my floor plan were missing. Please help ...a.nyone. I am working on a final
So far I have went in and turned all the layers on and that is still not helping...
9 REPLIES 9
Here is what it looks like when the floor plan is added to the PDF file. I have used the trace reference for this floor...fyi
Here is an example of what I can see in my 3d view and what I drafted on my floor plan which has now disappeared...
For clarification when I am in the screen to draft the 2d floor plan, I cannot see what I have previously added to the floor plan.
This is the last bit of information, but I chose to unlink all of the walls on my 1st floor. For some reason, this option was the only one that would let me access changing the height of the wall.
TMA_80
Check if you don't have duplicated the wall on the same place .
this used to cause something similar, afaik.
AC12_27 |Win11_64bit|
Thanks for your reply, I just saved my file closed out all my web browser tabs and restarted my computer. This seemed to help. I will try to check for duplicate walls. Thank you again and I will keep this is mind.
MrC
check floor plan cut plane also
ILIFFE ARCHITECTURAL
BRITISH COLUMBIA
macbook pro 2.7 GHz Intel Core i7 8 GB 1600 MHz DDR3 NVIDIA GeForce GT 650M 1024 MB
AC 21 USA (latest build)
1. You might have accidentally changed the home story of walls, and "show on stories" could be set to show "home story only." Or possibly set something in the model view options.
2. You will get better information if you include the version of AC you are working with. You should add to your signature.
3. You might consider posting a .PLA, and thereby getting an actual solution rather than guesses.
Richard
AC26 (since AC6.0), Win10
Nick Schat
When things go missing, first thing I check is the renovation tool settings.
Regards
Nick
ArchiCAD 4.1–22, Mac OS 10.14.x iMac 27" 3,2Ghz Intel-Core i5
