2011-05-05
05:07 PM
2023-05-26
12:31 PM
Rubia Torres
2011-05-06 02:32 PM
Steve wrote:The image has changed!
Thanks for sharing your project. I think it's cool.
As for how to make those pipes. Hmm...
That will be a bit of a challenge. Especially if it needs to be dimensionable, manufacturable, and constructible. I hope you will post the solution.
I have in mind a few things I will try but I don't expect to be able to do it very well.
Have you tried using the Spiral object in the Basic Shapes library folder?
This was easy using complex profile and some spirals of same dia.
2011-05-06 04:53 PM
2011-05-06 06:05 PM
2011-05-06 07:25 PM
2011-05-06 07:40 PM
Olivier wrote:How do I check 3D Axis on? I've searched for it (in Mac you can search for any tool etc. and it points you in the right direction), however never came up! Nor has the forum matched "3D Axis"
You can try 3D Tubing object in the library below (Tubes folder).
Follow insrtructions, and you will be able to do any path for a tube, in 3D window.
Work in wireframe mode with the lowest resolution (4), and check 3D Axis On.
A resolution of 12 is good enough for a rendering and a decent Polycount.
2011-05-06 09:37 PM
2011-05-07 12:12 AM
2011-05-07 12:54 AM
NStocks wrote:The model would work in exactly the same way irrespective of the profile shape. In this case, it was actually a custom profile (the underside is recessed for the fixing detail) and is about 7m long in total. This model was done to a very high level of accuracy because the components were manufactured directly from the model.
How did you get each piece to join up so neatly? Would it be just as easy to join a circular profile?
P.S How long is the continuos strip that was previously posted?
2011-05-07 01:10 AM
2011-05-16 10:09 PM
