2019-05-21
07:02 AM
2023-05-24
08:12 AM
Rubia Torres
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
Solved! Go to Solution.
2019-05-30 06:04 AM
2019-05-22 01:31 PM
2019-05-23 03:44 AM
2019-05-28 08:24 PM
2019-05-29 03:20 AM
2019-05-30 01:10 AM
Lingwisyer wrote:The duplicate will not generate by itself. It can be duplicated already on the source file, perhaps with different elevation links to story (one unlinked, the other linked, overlapping in space), and you are not seeing it there, but it suddenly becomes visible when the module gets placed somewhere; or one of them is in a hidden layer but getting published nevertheless as part of a nested module; in these cases both walls are in the same module. Or it is being generated when a single element gets published twice into two different modules (because 'include elements in other stories showing in this one' is checked), and the one getting published into 'the other' module loses the SEO in the process (which is what I would suspect); in this case each wall is in a different module. (And we are assuming no wall got accidentally copy-pasted/exploded from the module into the host file.)
The duplicate wall appears to be that of the wall being SOE'd. Single story content module, story to story offset.
2019-05-30 03:59 AM
2019-05-30 04:53 AM
Lingwisyer wrote:If you mean there are SEOs created in the host file between local and module elements, I think that is a bad idea. Any revision/redirection in the module, or replacement in the elements in the module, or in the local elements interacting with the modules, will kill them. In the rare situations where a SEO between a module element and some external element is absolutely needed I create a dummy SEO element on the module-creation file, and make sure the SEO layer is part of the module export layer combination. It is a duplicate, and manual work, but bulletproof, idiotproof, and easily traceable-debuggable.
only 2 of the 3 SOE operations applied to the wall are lost. They are all applied in the building model. Wall-Slab and Wall-Beam has been lost, but Wall-Wall has been retained.
2019-05-30 05:01 AM
2019-05-30 05:06 AM
PBC will take place first and then the SEO will apply.
