Hotlinked Modules improper Wall Connection
Hello !
After painfully adjusting wall intersections in a module I found out that they are not properly displayed in the original file.
Any ideas?
5 Replies 5
Lingwisyer
Guru
Can you post an image of your issue? How are they displaying? How are you wanting them to display?
Ling.
It could be your procedure.
If you have a PLN file that you saved a module from, and then you edited that module, you will not have changed the original PLN file - unless at the time of saving the module you ticked the box to 'Replace selection with module'.
Any file that contains the module should automatically update with the change the next time you open it - or it will let you know this it needs to be updated in the hotlink manager if the file is already open and the module is modified and saved.
I could've sworn that I attached this pic to the original post.
The wall intersections in question are a direct hotlink to the module, the original walls are long gone.
I figured out that the material properties in the project file and the module file have small differences and fixing this slightly improved the situation, but it seems that there's another cause(s).
Thank you for the responses.
Do you mean the connections are fine in the module file but not in the HOST file (this is different to the original file which would be where the module was created).
Could it be that your layer intersection priority numbers are different in the layer combinations used in each file?
If the walls are in different layers then those layers need to to have the same intersection priority number - you can find that in the layer settings dialogue.
Lingwisyer
Guru
Have you modelled the insulation as a separate wall the to wall itself? If so, do the reference lines overlap each other? If this is the case, I would move the insulation into a different Intersection Group.
I solved a similar looking problem with an exterior cladding that I modelled on to the exterior of a wall this way. Each time I loaded the file, the connecting walls would change how they would intersect... Or you could move the reference line.
Ling.
