How can I create a South African Cape Dutch gable wall?
Hi All,
I am new to the forum so please bear with me, I will try be as specific as I can be.
I am working with ArchiCAD 18 and what I am trying to create is a Cape Dutch gable wall as in the below image:
But I would like to have a gable window as shown in this image:
As it stands in the first image I have had to create 5 seperate walls and adjusted heights for each with a connect to roof/shell on the slanted walls.(created 2 seperate mono-pitch roofs to connect to and have hidden them)
Now the problem I am having is that as soon as I want to insert a window as per the below image:
it is only created in the inner wall and not the slanted walls which cuts my window on each end. I have browsed Google and forums to try and figure this out but I am afraid I'm stuck.
Is there any way to create a custom gable wall to be trimmed to the desired shape across the top without creating a morph, as with morphs you can't insert a window as you would in a normal wall.
Please if anyone has had a similar challenge and have found a solution please let me know! Thanks for the help in advance.
15 Replies 15
Erwin Edel
I find the rooftool quite handy to model the cap stones or whatever the covering that goes on top the wall is called in english. You can use the roofs to cut the wall as well.
Here's an example of an ArchiCAD15 project in wood, same principle.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Erwin Edel
Another example with bricks.
The nice thing about single plane roofs is you can use CTRL (or CMD) and click an edge to connect one roof to the other, so all it takes is 2 clicks to create perfect mitred joints.
www.leloup.nl
Tat looks great! But how do you get the gable wall to trim at that shape? I see you have it connected to roof/shell obviously, but nowhere could i find a roof that fit that shape other than creating a shell. What roof tool are you using?
Beautiful model, Erwin! 🙂
Erwin Edel
The shape is made up of single plane roofs. One horizontal and one with same pitch as the roof of the building. I trim the wall using solid element operators.
www.leloup.nl
Erich
Here is a similar example to Erwin's made in much the same way. However, since I needed profiled parapet cap stones, I used the crop to single plane roof feature which crops the wall then deletes the roof element used. This make the crop independent of other model elements which can be useful. The cap stones were then made with a complex profile wall - turned to a morph and rotated an needed.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
