2023-06-05 09:27 AM
Hi Everyone,
I am trying to figure out how and where to save the custom markers that I have made for my doors and window so that I can import them into my future projects and template. I see the option "load other window-door marker..." and would be great if anyone can help and explain how to save this custom markers and reload them into future projects as it will save me a lot of time.
I found this post which is way back from 2005 and doesn't help very much with the current version.
https://community.graphisoft.com/t5/Modeling/Door-Window-Marker/m-p/38259/thread-id/19006
Solved! Go to Solution.
2024-07-30 10:28 AM - last edited on 2024-07-30 10:45 AM by Barry Kelly
Hi!
I understood your answer, but I can not find door mark in Archicad library anywhere.
Is it possible that it is not awailable from Archicad 26 on anymore?
I clicked through all 2D symbols in Archicad and could nto find it ...
I wonder now how could I change Archciad default door stamp, so it would change in all doors at once.
2024-07-30
12:52 PM
2024-07-30
02:16 PM
This type of object is not visible in the object tool
You have to go to the libraries and objects menu
Here are screenshots from the French version
2024-07-30
01:37 PM
2024-07-30
02:17 PM
Thank you soo much!
I finally found it!
