How do I know "which" SEO operation I want to remove?
rob2218
I've got this mesh.
A while ago, I subtracted with upward extrusion the footing you see in the picture.
I want to "undo" (X) out that operation from the list. How can I find out "which" was that exact operation so I don't undo or "X" out another SEO operation I don't want undone....
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
Stress Co_
Scroll thru the list, stopping long enough for the operator to be highlighted.
It may be easier to see in the 3D window (do a marque or cutting plane thru your section).
Marc Corney, Architect
Red Canoe Architecture, P. A.
You can also do it the other way - select the Operator and see the list of elements it is operating on. It may be a shorter list (or at least have less meshes operated upon).
Also, if you have a unique ID for the footing, the ID should appear in the list of operations making it easier to pick out.
rob2218
wow guys...I can see it 3d alright...it's highlighting the objects that are affecting the target...very nice indeed.
thank you both.
i>u
Edgewater, FL!
SOFTWARE VERSION:
