2016-07-2202:18 AM - last edited on 2023-05-2407:57 PM by Rubia Torres
I've got this mesh.
A while ago, I subtracted with upward extrusion the footing you see in the picture.
I want to "undo" (X) out that operation from the list. How can I find out "which" was that exact operation so I don't undo or "X" out another SEO operation I don't want undone....
...Bobby Hollywood live from... i>u Edgewater, FL! SOFTWARE VERSION: Archicad 22, Archicad 23 Windows7 -OS, MAC Maverick OS
Scroll thru the list, stopping long enough for the operator to be highlighted.
It may be easier to see in the 3D window (do a marque or cutting plane thru your section).
Marc Corney, Architect Red Canoe Architecture, P. A.
Mac OS 10.15.7 (Catalina) //// Mac OS 14.5 (Sonoma) Processor: 3.6 GHz 8-Core Intel Core i9 //// Apple M2 Max Memory: 48 GB 2667 MHz DDR4 //// 32 GB Graphics: Radeon Pro 580X 8GB //// 12C CPU, 30C GPU ArchiCAD 25 (5010 USA Full) //// ArchiCAD 27 (4030 USA Full)
You can also do it the other way - select the Operator and see the list of elements it is operating on. It may be a shorter list (or at least have less meshes operated upon).
Also, if you have a unique ID for the footing, the ID should appear in the list of operations making it easier to pick out.
