Kasski
How do I make roof design like this?
Hi.
How do I make roof design like these houses?
I have tried with roof tool, but the modeling doesn't allow large angles.. and I have the same problem with shell tool.
Hope you understand what I want from these tree examples.
Thanks in advance
https://www.sparchs.design/copy-of-copy-of-copy-of-copy-of-copy-of-copy-of-copy-of-page-temp-1
https://www.sparchs.design/page-temp
https://www.agabarkitektur.com/villaaj
2 Replies 2
runxel
Hi @Kasski, this is absolutely achievable, but it is kind of hard to input this "free hand" with the roof alone.
Instead for articulated roofs like this I would rely on the Mesh-to-Roof Goodie.
So you would make the roof with the Mesh tool first, so all heights are exactly where you want them, then you can convert this mesh into one or many roofs, depending on the geometry.
Ricardo Lopez
Hi @Kasski
You can try the Shell tool with Extruded Geometry Method , create as much as you need, right-click and Define Shell Contour and Create Hole in Shell if needed, as Solid Element Operations or Opening tool for windows, doors or croppings.
Ricardo López, M. Arch.
