2008-04-10
01:45 PM
2023-05-23
03:11 PM
Rubia Torres
2008-04-12 05:46 PM
lamour wrote:Hi Lamour,
I have downloaded and run through the tutorials which are good but they don't help me with creating any cladding be it; roof or wall never mind ribbed, micro rib or smooth cladding panel.
2008-04-12 07:57 PM
lamour wrote:You would be better off calling us the Archicad Gits.
I am currently involved with a university project where i must show my 3D skills in Archicad but I am fairly new to Archicad 11.
eventually It would be good if you can enter a panel size (w x h x thk) and spacing to the next panel so when the rendered image appears it looks spot on.
When i tried on AC 8 i used a library component with worked well until it came to the corners of the building. Unless the building dimensions match the library part exactly i was left with a real nasty overhang. Maybe i was very close to solving the above.
please help me you archicad gods !!
2008-04-13 09:11 PM
2008-04-14 10:29 AM
2008-04-14 12:57 PM
lamour wrote:they are libraries. but don't load the texture library unless you want several thousand RAL colour material attributes to be created. (you don't
I have downloaded the kingspan files and I will install and have a look. Not quite sure what i will be installing, are they library components and textures?
