Mats_Knutsson
Mentor
How should I do curbs?
I've created a curbs by using a complex profile and a custom linetype. First of all it works in 3D but the 2D is not being friendly. Basically I have a curbs section I pasted into a complex profile. I want different line types on the different sides of the curb to indicate which side is which. Therefore i created a special line type with a hotspot offset. You can see everything in the vid. If you have any other suggestion I'm happy to listen :).
And yes I want it in 3D 🙂
https://youtu.be/dU2X6LIwRlA
Br,
Mats
AC 25 SWE Full
14 Replies 14
 Hello Mats_Knutsson,
Did you try to model it by pushing space bar before cliking on your guide line ?
Did you try to model it with beam to be able to modify altimetries ?
Did you try to modify it with railing tool ?
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
Patrick M
I use meshes for curbs, but you can also do them with walls, slabs, or railings, depending on exact site conditions and design needs.
Mats_Knutsson
Mentor
Salut Christophe,
1 Magic wand at 1.38
2 I didn't. Focussing on accurate 2D appearanceand 3D length.
3 I haven't managed to get a solid line along one side of the rail and dashed on the other side with the railing tool. And I need to draw the curb along a side...
If the wall tool had the option of different line types for reference line and the other line...
AC 25 SWE Full
Mats_Knutsson
Mentor
I need accurate 2D and quantity. I have no probs modeling nice 3D curbs but that's actually not the most important part. I'm creating a template for our landscapers and they need as good as or better compared to what they can do with their Autocad plugin.
AC 25 SWE Full
Gerry Leonor
i found that creating curbs using the beam tool with a complex profile is fine for simple flat sites. if you need some change of elevation, angled beams do OK too. where it gets tricky, is when you have one end of beam curb that's lower, the other end is higher AND it's a curve. i found that you can't have curved angled beams higher at one end than the other. maybe a morph tool using the same complex profile will work -- i haven't tried it yet.
with regards to your video question, after you've drawn the first straight curb, instead of clicking the button in the pet palette for a curve, keep drawing the straight curb for both curves for now. re-select the beams, then edit them to be curves. (shared video below. i hope it works)
https://1drv.ms/v/s!AgnwiRVSv3c_mMReHDxzEmhT8cOsNw
https://discord.gg/XGHjyvutt8
Djordje
For me, railings work best
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Mats_Knutsson
Mentor
I haven't managed to trick the railing to show a solid line along one side and a dashed line along the other side...!?
AC 25 SWE Full
Djordje
Hmmm... yes, it does require some playing with the representation settings and what is shown where... I separated the part above ground into "toprail", the foundation into "handrail", etc...
It is probably easiest to do only for the modeling with the morphs (hint: for closed outline, ALWAYS join at the middle of the straight portion) but the quantities come out waaaay better with the railing.
Djordje
HP Omen
Mats_Knutsson
Mentor
yes I know I can do like that but I prefer the tool to work as it should. It's a bug afaik.
AC 25 SWE Full
