2026-06-26 05:17 AM
Hi i've been wondering how to align cut fill to reference line, image attached shows that it works fine with up-down left-right wall, but it messes up when the wall was curved or in diagonal. is there any way to align the cut fill to reference axis?
Solved! Go to Solution.
2026-06-26 06:27 AM
I know it can align with the wall as long as its straight, I doubt it can be done with a curved wall.
Check the setting in Building Materials and fill orientation associated with your material.
2026-06-26 07:34 AM
If your fill type is Symbolic, you can use the "Fit to Skin" option. This will curve with your elements.
2026-06-26 06:27 AM
2026-06-26 07:34 AM
