2013-12-16
06:32 PM
2023-05-24
09:05 AM
Rubia Torres
2013-12-16 07:02 PM
2013-12-16 07:30 PM
NCornia wrote:Thanks, that seems to be working! Still getting a bit confused when the references suddenly change, but I'll figure it out. Appreciate the help
bhagwad,
If using ArchiCAD15 or above:
A. Activate a Guide Line along the wall's face or reference line. See: HelpCenter: Display a Guide Line Along a Particular Edge
B. Click the point where the second wall will join and move your cursor in the direction the wall should be drawn.
C. The angle should now be relative so you can now type A for Angle and input your desired value, a long with D for Distance to define the length of the wall.
Best regards,
