Edo0629
How to Extrude a Helix with an Even Surface in Archicad?
Hi everyone,
I'm trying to extrude a helix by 5 cm in Archicad, but I'm running into an issue. The extrusion creates an uneven surface, and I haven’t been able to find a solution to make it smooth or uniform.
Is there a tool or technique in Archicad that can help me extrude the helix while keeping the surface even? Any suggestions would be greatly appreciated.
2 Replies 2
Olivier-IDAO
Hi Edo
Try the curved ramp object in the library... That should do the trick.
Olivier
Interior designer, Former & Bim expert
Archicad 6.5 to 29
MacStudio 2023 Apple M2 Max powered by MacOS Sonoma 14.7.4
alemanda
Draw a beam in the plane.
Wider than high rectangular section.
Transform into morph.
Move up and down the extremities to get your favourite geometry.
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
