2023-03-25 02:08 AM
I can't think of how to extract length of Casing from the default door and window objects.
I do it in other ways. But it seems like somethign that should be possible to do with the default doors and windows.
Solved! Go to Solution.
2023-04-05 02:55 AM - edited 2023-04-05 02:55 AM
That is correct.
The expressions in properties only affect the element they are associated to.
The schedule just tallies those figures from the elements.
The schedules do have a new merge option for each field (merge items must be on to use this).
That can give you a bit more control for how elements are tallied.
2023-04-20 01:57 PM
take the time to learn how to write property expressions....
there is soooo much control over your data here....
