How to YOU use an Interactive Schedule to display lengths of Door Casing?
Steve Jepson
I can't think of how to extract length of Casing from the default door and window objects.
I do it in other ways. But it seems like somethign that should be possible to do with the default doors and windows.
11 REPLIES 11
That is correct.
The expressions in properties only affect the element they are associated to.
The schedule just tallies those figures from the elements.
The schedules do have a new merge option for each field (merge items must be on to use this).
That can give you a bit more control for how elements are tallied.
take the time to learn how to write property expressions....
there is soooo much control over your data here....
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
