‎2008-11-12
07:24 AM
‎2023-05-25
05:51 PM
Rubia Torres
‎2008-11-12 07:57 AM
‎2008-11-12 08:39 PM
‎2008-11-12 11:36 PM
ELing34 wrote:Circle target means you have found a node of an element, square target means that you did not, Dimension points dimensioning those circle targets will be associative, those dimensioning square ones will be static.
I have done this before and somehow it's not working anymore. When I try to angle dimension my weird floor slab, I click on a point, it sometimes gives me a circle target and sometimes it gives me a square target. What I use to do is to click 2 points, double click on the outside and it will give me the angle. Now, when I click on the two points (one square and one circle), it refuses to give me anything. What is going on?
