How to cover the edge/periphery of a composite Slab.
Hello Friends,
I need a suggestion regarding composite slab. I am having difficulties while trying to cover the edge/ periphery of a composite slab.
How can I cover the edge/periphery of a composite Slab.
6 Replies 6
When you say you want to cover the edge of the Slab, what do you mean by that?
Do you want to create an edge profile?
Could you draw the desired result in 2D and post a screenshot about it? Or draw how the section of the Slab edge should look like?
I have no idea about edge profile.I don't want to use complex profile. I didn't use it yet? Please see the attachment. This is an composite slab made of Rcc in core and plaster on both side . I just want it's edge to be covered with the same plaster
Dontknow
The easiest way to get this done is to draw a beam along the slab, i think.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
DGSketcher
Legend
Dontknow has shown a good solution, but if it is just a 3D visual problem you can simply use the edge surface material override. At a more detailed level, if the slab is supported, (they usually are), then the slab could be built into the supporting structure and Priority Based Connections (PBC) would take effect and the wall finishes could cover the edge of the slab.
You may find this link helps with your designs... https://helpcenter.graphisoft.com/user-guide/88747/
Dontknow
You can't give a thickness to a edge surface material override (I think ).
This also shows good in a section.
ArchiCAD 25.
jl_lt
Ace
What mr. dontknow proposes is one solution, another one is to cover that edge with the finishing of the wall or the composite you are using. Check this video. Its in spanish, but what i mean starting at minute 11:30
