How to create an area light with a size smaller than 10cm?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2024-09-15
08:07 AM
2024-09-17
12:03 AM
Guys, I'm trying to create an area light smaller than 10cm (I want to make an LED light 3cm wide).
The problem is that archicad does not change the area light property when I customize one of its dimensions to a number smaller than 10cm, and this causes my render engine to use these values instead of 3cm, making the lights in the render they are poorly positioned/with wrong sizes...
If you look at the image I attached, in the blue circle are the measurements I customized, but up there in the red circle, the limit dimension seems to be 10cm... I wanted to change that...
How can I customize the light area so that these values above (which I indicate in the attached image in red) are also changed?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2024-09-16 02:11 PM
The dimensions in the red circle include the cross hairs outside the square box. If you measure the square box in 2D or 3D, it is the Length and Width sizes. I can input 1/16" (1.6 mm).
www.davidmaudlin.com
Digital Architecture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2024-09-16 04:55 PM
Hello David!
Thanks for your answer!
I'm currently using Archicad 27!
I can understand what you are saying, but my problem is with those measures of the crosshairs... I need to change them, because my render engine software reads those measures to translate the lights from archicad to it's software... I will give you an example: if I make an area light with the measures of 1 meter x 3 centimeters... in my render engine the area lights are translated with the measures of 1 meter x 10cm (because of those crosshair measures). And this is causing me much trouble with the render engine related to light positioning and dimensions... =/
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2024-09-17 02:41 AM
The light object does indeed have a crosshair that is a minimum size of 10cm.
I don't know why your rendering software is using that information, I would have thought it would use the 3D size of the object.
Maybe try playing around with the settings on the next page to change the 2D symbol.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2024-09-17 04:28 AM
