How to draw a property boundary from a survey??
rob2218
in Autocad there was a way inwhich you could precisely draw the meets and bounds off of a legal survey. for example, when the properly line says..."S38D22'13"E" there was a way in autocad in which these lines could be drawn to their real world points.........how is this done in archicad?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
6 REPLIES 6
Eduardo Rolon
Project Preferences -> Working Units
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
rob2218
thanks...but can you be a bit more elaborate on what you mean by that?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Eduardo Rolon
In your project preferences change your working units to surveyor in order to input the information with the surveyor's annotation. Once you do that the procedure to draw the lines is the same as in Autocad.
AC28 US/INT -> AC08
another Moderator
rob2218
thanks...did that but still doesn't help me in accurately placing lines from a boundary.
Boundary surveys have those 226.56' @ S27 32' 33"E means of measuring the lines of a property. How do I make the pline go to where these surveyors numbers take them???
in autocad, we used to actually input a distance and a surveyors angles but I'm at a loss as to how to do it in archicad.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Eduardo Rolon
Type "D"
Type "Distance" 226.56
Type "A"
type "Angle" S27 32' 33"E
AC28 US/INT -> AC08
another Moderator
ejrolon wrote:
S27 32' 33"E
BTW: you don't need the minutes and seconds marks.
s27 32 33e works as well.
