It is a little difficult to see in your image what it is that you want to accomplish for sure.
It seems that you have a wall running into your arched opening to the left of the stairs, and that you want a partial arch ending at the opening, rather than the full arch which is leaving the odd piece of wall?
The best method is to create a custom shape for your opening, as David suggested - deleting the arched opening that you placed in that wall. Create a section through your model to draw the desired shape. You can create a Morph with the new Morph Tool right in the section ... and then in 3D, drag the 2D Morph and extrude it to penetrate the wall... then do a Solid Element subtract.
Or, you can create the shape in the section to be used with a Complex Profile.
Either way... this article will help you:
http://www.archicadwiki.com/CreateCustomOpening
(The article was written before the Morph Tool became part of ArchiCAD.)
See also:
http://helpcenter.graphisoft.com/guides/archicad-17-int-reference-guide/virtual-building/element-ext...
AC 28 USA and earlier • macOS Sequoia 15.3.1, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
