Inglewood78
How to show Fill pattern in floor plan?
I would like to setting plan view for show Fill pattern as i setting in materials not override graphic.?
Please suggest for me please.
2 Solutions
kmitotk
Kei Mito
MITO architecture + design
Architect | Graphisoft Certified BIM Manager
ArchiCAD 29 JPN/USA/INT | Windows 11
Go to post
By default a slab will not show a fill in plan.
But in the slab settings you can turn the cover fill on.
You can set any fill you want or set it to use the fill defined in the surface material.
Go to post
3 Replies 3
kmitotk
Kei Mito
Inglewood78
Thank you so much . This is what i want and sorry for my noobie.
