2013-11-13
10:47 PM
2023-05-24
09:07 AM
Rubia Torres
2013-11-14 03:39 AM
2013-11-14 04:10 AM
Peter wrote:It is actually the CTRL key - for Windows users.
Hold down shift, and you will see the cursor change to a little pair of scissors.
Peter wrote:Not if you have the tool active for what you are editing.
At the moment as you rightly say, you can only trim elements one at a time. In certain circumstances drawing a multi-segmented line across several elements to be trimmed at once is much faster. They wouldn't necessarily even have to be in a straight line.
2013-11-14 04:21 AM
2013-11-14 05:09 AM
2013-11-14 08:34 PM
2013-11-14 10:31 PM
2018-10-26 10:57 AM
Command key for Mac?
i.e. if you have 6 walls to trim to another wall or slab edge, line, curve or whatever then select those walls and have the wall tool active.
Now CTRL click on the edge you want to trim to and there you go.
It doesn't have to be a straight line - can be curved.
Doesn't work to polygon type elements so well as they will all trim to the edge you CTRL click and not the entire polygon perimeter.
2018-10-26 11:03 AM
Lexi wrote:This is only for trimming/extending the length of wall (or lines) to a reference edge.
Hi Barry, this doesnt seem to work for curtain walls which is what i need help with. my curtain wall is on a slope and has an wall intersecting that needs trimming. any ideas how to do this? Thanks.
2022-10-18 03:45 AM - edited 2022-10-18 03:56 AM
Are you saying that multi trim is possible?
If possible, may I ask for an explanation that a beginner can understand?
