I would like to apply hatching on an element basis.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2023-09-15 01:24 PM
Since it is based on the entire hatch, the wall is tilted and the hatch looks strange. I would like to apply hatching on an element basis.
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-09-15 01:41 PM
In the building material settings, you can set the fill to 'Element Origin'
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-09-15 01:41 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-09-15 02:10 PM
omg....
It's not inside the wall. ^^
When you create a new material style, it doesn't combine with each other.
It seems like ArchiCAD got it wrong.
It may seem far-fetched, but there are cases where things like this happen. ㅠㅠ
thank you ^^
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-09-18 01:37 PM
1/ Archicad will only combine fills with the same building material (a new material style = another building material)
2/You're making a very unlikely combination of walls. I would suggest using a patch to solve the 2d views.
AC27
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-09-25 12:54 AM - edited 2023-09-25 01:09 AM
Seems OK to me.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-09-25 03:30 AM
You are not wrong that there are some problems with the way ArchiCAD merges building materials, and other things too.
For example, using the fillet tool to make a rounded corner.
These are the exact same wall types. But the lines look wider in the curved part and the fills do not align very well.
And I really don't like the segmentation for any Elements in ArchiCAD. This is never going to get any better until they change over to Nurbs.
I don't care if it doesn't make any difference to the people using the Plans - I don't like to see it while I modeling! The segmentation for curved walls (for example) looks terrible in my preferred rendering program.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-09-25 06:51 AM
I also agree with your opinion. ^^
ARCHICAD seems to have a problem with the curved part.
