Importing 3D files
Can anyone tell me if its possible to import other 3D model types into ArchiCAD projects, if so how is it done and what file types can ArchiCAD read.
Specifically i've been given an Autodesk Inventor (?!?) model and am wondering if i can get it into my ArchiCAD model.
Please help, i'm going mad!
Thanks.
2 Replies 2
Djordje
It is; the issue has been widely discussed here. Most common are the usually most coomon - DXF and DWG. There is also a 3DS import API that Stefan posted relatively recently. ArchiCAD 7 could also import OBJ. If you have a ZoomGDL lying around, it can also be used for converting 3DS to GDL.
You import the 3D model as a library part. Go to File/GDL Objects/Open Object and choose DXF or DWG as file format.
How is it going to come out depends on many factors ... I posted a link to a "tutorial" posted on old ArchiGuide many times here; check also Resources forum.
Inventor is mechanical modeling software; very parametric etc, but I seem to remember that its file format is anything but open. You might want to check UpFront eZine web site for more writeup.
Nope; although you might be lucky with one of the 3D converters to something else, namely DWG, DXF or 3DS. And I suppose our 3D compatibility expert Stefan will have an advice or two ...
Good luck!
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Djordje
Go to
http://www.graphisoft.com/archiguide_archive/ArchiGuide_Online_6o/ArchiveFrame.html , issue 20. Some other intersting stuff around, too!
Also here:
http://www.graphisoft.com/support/archicad/archiguide/importsolids.html
Djordje
HP Omen
