2007-01-18
11:25 PM
2023-05-30
02:04 PM
Rubia Torres
2007-01-19 12:58 AM
2007-01-19 01:29 AM
TomWaltz wrote:
You can turn the Line Weights off under On-Screen Display Options (I think under Design, but I have my own drop-down menus so I cannot say for sure)
2007-01-22 07:12 PM
TomWaltz wrote:Am I correct in assuming that ArchiCAD 10 will open plotmaker files? I open a Plotmaker file in Plotmaker and check to make sure that it has the default firm/project graphic layout that I'm looking for but then when I try to navigate-browse to open for the exact same document from ArchiCAD they don't show up in the same folder. I can now find the layout templates that I'm looking for-at least Plotmaker file layouts-but only when navigating to them from the windows environment, none of these files will show up to open from ArchiCAD. What silly thing am I doing wrong here?
Open the LBK in Archicad 10 and save it as an AC10 PLN. AC10 will create the necessary masters, then you can import them into another file.
