Tom Krowka
Importing display options
Any way to import existing display options into another existing project. I'm trying to set up a template, have everything all set except for display options.
I found an article in archi-guide, but it references V8.1. Any easier way way to do it in V9. The 8.1 way to do it makes me start from the beginning with DOs.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
AFAIK: The display options are not transferable since they are neither attributes nor part of the work environment. An unfortunate oversight by GS. You could merge the file with the model in it into one with the correct display options, but this may be more work than it's worth if you have developed elevations to copy/paste.
A link to Laszlo Nagy's article for anyone wondering:
http://www.archicadwiki.com/TechNotes/Display_Options_Combinations_cannot_be_imported?highlight=%28d...
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
