In Sections Settings; What does "Drawing" Accompli
Could not find in HELP what "Drawing" choice Accomplishs in Section/Elevation Default Settings > Status of Section/Elevation View > Drawing?
Thanks,
Joseph
4 Replies 4
Dwight
Soometimes you need an image that is not interactive with the model.
So you ask the section to be a drawing instead of an updating view.
Dwight Atkinson
TomWaltz
It takes the model view and explodes it to lines and fills.
The benefit of that over the AC9 equivalent is that you can turn it back into a model view if you need to.
Tom Waltz
Rod Jurich
Tom, in AC9 you can also revert section/elevs to Autorebuild
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
TomWaltz
I guess I'm thinking 8.1 maybe? I know the ability to switch back and forth was relatively new.
Tom Waltz
