Inconsistency selecting roofs? - version 22
In the 22 user guide there is a "Small Improvement" noted ...
• Selection of overhead elements in Floor Plan now omit their surface detection, to give priority
to selection of uncut elements. Select overhead elements by their outline.
This is fine, but am I not understanding something or is there an inconsistency happening here?
If I have any roof (single or multi plane) and the Floor Plan Display is set to 'Projected with Overhead' or 'Overhead All', then I can not select the surface of that roof - must select it by the edge.
This is consistent with the above statement.
If I have a single plane roof set as 'Outlines only', I still can not select any surface.
Again consistent with the above statement - although technically it is not set as 'Overhead'.
Now when I have a multi-plane roof set as 'Outlines only', I can select the surface.
So which one is inconsistent?
I would like the single planes when set as 'Outlines only' to be selectable by their surface, because as I said technically they are not set to overhead.
Or am I just missing something not quite so obvious to me?
Thanks for the offer Daniel, but I just figured out what the problem is.
Legacy mode.
We have the legacy mode on for single roof planes (which we still use a lot).
A setting we made in out template when we switched to version 15.
There was a reason for it at the time but I can't remember now (double edge lines for non vertical edges maybe?).
Just one of those settings that has always been on - just because.
I will have to look into it again and see if we can't switch it off now.
6 REPLIES 6
Also the physical height of the roof seems to have no impact on the surface selection.
Even if it is entirely below the Floor Plan Cut Plane height, a single roof plane will not select by surface.
I just also noticed adding a cover fill to the single planes will allow surface selection - even an empty fill will do.
But the multi-plane roofs do not need a cover fill at all.
Another inconsistency? - but a solution for a work-around.
Daniel Kovacs
Graphisoft Alumni
I can not reproduce the same behaviour here from the INT template. When I set it to outlines only, it will always have a fill for me to select, and if it is set to overhead all, then it will not - regardless of whether it is a single or multi-plane roof.
Can you send me the file in which you experienced otherwise?
I am on v22 4023 (latest update), maybe that is making a difference?
Thanks,
Daniel Alexander Kovacs
GRAPHISOFT
Legacy mode.
Erwin Edel
Barry, I think the legacy setting has to do with how skylights are shown.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Yes it will affect the skylights but as I thought, if the roof edges are not perpendicular and the bottom surface is larger than the top surface, then you will see a double lined on each edge.
This is because when legacy mode is off, the plan for roofs is a top down view and what you see is what you get.
Erwin Edel
If you merge your single plane roofs, these lines will disappear.
www.leloup.nl
Windows 10 Pro
