Incorrect information in door schedule
I am having trouble getting ArchiCad to correctly identify the door leaf size when creating a door schedule.
I want the door opening to dimension 900mm when I use the automatic dimension tool but I want the door schedule to give me the leaf size of 820mm. I generally use the D1 Metal door and I need to adjust the frame width to 52mm to give a 900mm opening with 820mm leaf.
I am using ArchiCAD 8.1 R2. AUS.
Is it possible to have the door schedule read the opening minus the frame width?
Thanks
Michael
2 Replies 2
Steve Jepson
did your try turning on the rough opening option ?
Steve ..... I dont have the rough opening option I have tried a few different door types and none of them have it .....
