Incorrect information in door schedule
I am having trouble getting ArchiCad to correctly identify the door leaf size when creating a door schedule.
I want the door opening to dimension 900mm when I use the automatic dimension tool but I want the door schedule to give me the leaf size of 820mm. I generally use the D1 Metal door and I need to adjust the frame width to 52mm to give a 900mm opening with 820mm leaf.
I am using ArchiCAD 8.1 R2. AUS.
Is it possible to have the door schedule read the opening minus the frame width?
Thanks
Michael
did your try turning on the rough opening option ?
Steve ..... I dont have the rough opening option I have tried a few different door types and none of them have it .....
