Link
Thanks for taking the time to jump in, much appreciated. I still think I am missing something or maybe not explaining my dilemma clearly enough. I have no problem putting in the work to set up templates and standards (I am constantly tweaking those I have already set up for the office) We in fact do change penweights in plotmaker for unique situations already, although for the most part we use uniform pens and colors to keep it simply for most users, but that's another story.
If I am using the S/E tool to do Interior Elevations, the "cutline" is some distance away from the face of the cabinet (in my original scenario) therefore, using the method you describe, all of the lines in the elevation of my cabinet are pen 18 (from your method) which still does not address what I am looking for. The only thing that would be cuts and fills would be floors and walls bounding the space. Being able to change the lineweights in Plotmaker really doesn't help me in this situation. It does let me have a different lineweight in the plan view and elevation view of the same object, so it fixes one issue, but it does not let me have different weights for different edges in the same object, which is really the biggest problem I have.
Based on hand drafting standards, which is what partners/principals who have no CAD skills want to see, the outside edges of this cabinet should be a heavier line than the lines on the face. I would think that this is an issue that everyone out there has to deal with as this is common drafting practice. The way I see it there are three possible answers to the question:
1. everyone is doing some sort of workaround? (And if everyone is doing a workaround then isn't that something that should be addressed in the software?)
2. this notion of the outside edges of an object in elevation being heavier than the lines on the face is not a standard that others use?
3. I am just not doing something right?
kevin s burns, AIA
massachusetts, usa
AC25 (1413), since AC6
Windows 10
Intel Core i7 -8700 @ 3.2 GHz~ 16 GB ram
