Intersection Priority for a Wall, when Attached to another wall
If I have a corner where three walls meet, on the left side, I'm able to solve the intersection priority, but if I have this single wall just attaching to a middle of a wall, then what can I do to make it intersect correctly, like the one on the left?;)
3 Replies 3
Lingwisyer
Guru
Your blue is stronger than your dark green?
Well, I'll be a monkey's uncle;)
Thanks
Steve Jepson
In regard to many of the recent questions about intersecting walls skins (all good questions) - but there is a solution that makes them all go away. Don't display all the skins in the Floor Plan views. Use graphic overrides to display lines of the Core Only - and with Wall Tags. Show all the skins in a larger scale Wall Types Legend where the skins of each wall can be easily labeled and also have a corresponding Wall Tag. Showing all the skins of a wall is seldom useful in a Dimension Plan/Floor Plan for the people who are constructing the building. And make dimensions to Core Only as much as possible.
