Intersection Priority
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2019-11-02
01:55 AM
2023-05-09
04:19 PM
Rubia Torres
2019-11-02
01:55 AM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-11-02 02:14 PM
2019-11-02
02:14 PM
Usually I do this kind of detail by this way :
1 composite wall - green
1 slab - orange
___________________________
SEO between them
At last 1 composite wall about fondation (blue)
Since AC22 we are able to create "dynamic" wall profile to edit them easier
1 slab - orange
SEO between them
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-11-04 10:25 AM
2019-11-04
10:25 AM
You can create your Wall by defining a Complex Profile (just convert your Wall's Composite Structure to a Complex Profile) and add parametric modifiers to it. One of the modifiers would control the bottom of that Skin. When the Wall is generated, you could simply shorten that Skin so it end at the top of the Slab.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-11-05 03:09 AM
2019-11-05
03:09 AM
Amer, I have deleted you other post.
I basically replied there the same as Laszlo suggested.
Here is what I said...
The connection is controlled by the Priority Based Connections (PBC) of the wall and slab.
As the wall continues below the slab, there is nothing there to cut it away.
So one solution would be to add an extra 'void' under the slab composite to effectively make it thicker to cut the wall away.
But a better solution is to create a complex profile of the main wall and add a 'modifier' to the base of the external skin so that you can stretch it to the required height of the lower wall.
Or you could add in a 3rd wall that is literally just the external skin at the side of the floor slab.
