Issue placing a window in a complex profiled wall.
I have an 18" straw bale wall (just a core and 1" plaster skin on each side) that I created as a composite and it works fine in all respects. I captured the wall as a complex profile and now all windows inserted in a wall with the profile applied show as a dot in plan. They look fine in 3d and elevation. Is this something simple I am missing?
Thanks, Matt
3 Replies 3
I found that there is an error with the 2d symbol script. This is the error I got.
Djordje
Matt,
THe issue you are describing can happen, and the results depend on your library. Please do a search, and a library update, before continuing, if possible?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Matt,
See this thread for a fix to the wa_trim_us_10 macro by Matthew Lohden. This might solve your problem
http://archicad-talk.graphisoft.com/viewtopic.php?p=79827&highlight=watrimus10#79827
HTH
Dan K
