Julia Ozols
Issue with importing 3Ds
ArchiCad 26 INT
Installed Goodies_Suite-26-INT-3000-1.0
Installed Archicad-26-INT-Update-5002-1.1
No menu 3ds studio appeared
Any tips, what may be wrong?
3 Replies 3
Guru
Have you added the Goodies library to your file?
Win11 | i9 10850K | 64GB | RX6600 Win11 | i9 11900K | 32GB | GTX2080TI
If you have installed the goodies after you have already used 26, there is a bug where the commands will not be added to the menus.
Solution is to manually add the commands to your menus in the Work Environment.
Or easier, is to re-install Archicad itself
No need to un-install.
Re-install and use the 'repair' option if it is offered.
Do not start Archicad.
Install the goodies.
Install the latest update.
Now start Archicad and the commands should be there.
Jasen Langley
2 versions later.....Had to do this for version 27 as well.
Also note, I imported my Work Environment of my previous uses and now the 3D Studio is missing.
Now I can go through and apply this to my old settings, but I think it would be nice to just right click in these fields then go to the version I want and paste the option I just right clicked on.  Maybe, some how apply the feature of the Project Chooser > so you can easily see what you get, then I can have the Default version 27 and see the (in this case) 3D Studio then drag it over to my current settings.  This is a feature if you're not familiar with or do not use over and over you have to do a refresh course to get things to work correctly.  Just saying, "work Smarter not Harder".
Jasen Langley | ARCH720
ArchiCAD v27 (since v09) macOS Sonoma (version 14.4)
Apple M2 Max Studio, 12-core CPU, 30-core GPU, 16-core Neural Engine, 1 TB SSDrive
64 GB Memory
