Issues with modeling in 3d - height stretch - AC27
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2023-11-09
05:17 AM
‎2024-02-06
12:26 AM
Hey all,
Having issues with using the 'stretch height' command in 3D. It seems to jam up the program, the only way to fix the issue is click off along the top bar of the window and then back into the working space.
Seems to be happing across the board with this command in 3d - not just isolated to cabinets.
the X marks where i need to click to get it back. This is the same across a team of 8.
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2025-02-12 02:50 PM - last edited 3 weeks ago
I would like to inform you that this issue was fixed in Archicad 28.1.0 Update. Please note that the fix is "switched off" by default because it causes a slight performance decrease in drawing update. A registry setting should be adjusted to activate the fix:
(Important: Make registry changes at your own risk. If you are not technically prepared, please contact your support team for assistance.)
- Close Archicad if it is running.
- Open the Registry Editor application and navigate to this directory: Computer\HKEY_CURRENT_USER\Software\GRAPHISOFT\Debug\DG.
- Double-click on "CefUseBackgroundPriorityMessages" and change its value to 1. (Switch it back to 0 if you would like to deactivate it.)
Please note that the switch is not version-dependent, so once you change it, the fix will be activated in all installed Archicad versions equal to or newer than Archicad 28.1.0 Preview Update.
Kind regards,
Oleksandra
Oleksandra Vakariuk
Technical Support Engineer
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-11-10 02:51 AM
Having the click on the AC window header would imply that when you are selecting the Height Stretch option, something is causing the AC window to cease to be the active window. If you are on Windows, you can confirm this was the header text will fade out. On macOS, I believe the window buttons at the top right change.
Could you boot in Safe Mode then start a new AC project with no addons loaded?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-01-17 07:16 PM
Hello @tomyg,
I am having the exact same issue on my desktop, but it works perfectly fine on my laptop, so I am suspecting it has something to do with the hardware/drivers. Since it is happening in 3D, maybe something is worng with the GPU or its driver?
@Lingwisyer, That is not the case, the window is still active, it just freezes.
Have you been able to resolve this? What was the solution?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-02-03 07:28 PM
I am facing the same issue and yes, clicking anywhere "outside" is the only way to terminate the jam.
LENOVO/ LEGION PRO 5/ 13th Gen Intel(R) CoM) i7-13700HX 2.10 GHz/ RAM 32,0 GB/ NVIDIA GeForce RTX 4070 Laptop GPU/ Windows 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-02-03 07:33 PM
On the contrary, I am facing the same issue on my laptop. It's a Lenovo Legion Pro 5, with GPU NVIDIA GeForce RTX 4070.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-02-03 07:34 PM
GS, please address this problem
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-03-12 09:32 AM
Same issue here.
Apparently it is already logged as a bug: DEF-16609
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-04-16 05:14 PM
I am having the same issues. It happens on both my laptops. It doesn't happen in V26. I am interested when an update comes out if they are working on it already.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-04-18 10:47 AM
I'm also experiencing this issue, and clicking on the window top bar doesn't seem to work.
Is there an update on this bug?
Designer Innovator + Generalist
Architecture, 3D Visualization, Web Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-04-22 07:17 PM
i can't help but notice how archicad is getting more and more stupid and lazy in creating really useful and actual tools. No AI and other...
