2015-11-12
08:53 AM
2023-05-24
08:45 AM
Rubia Torres
2015-11-12 09:29 AM
2015-11-12 09:41 AM
2015-11-13 04:02 AM
2015-11-13 04:34 AM
2015-11-13 06:17 AM
2015-11-13 08:26 AM
2015-11-13 08:52 AM
Barry wrote:Thank you very much!
Found it.
It is called 'Change Flip Status' and I think the default shortcut is 'P'.
But I think I will set it as 'C' so it is the same as older versions and use 'P' for the reference line location (or 'P'osition) i.e. construction method.
2015-11-13 08:58 AM
Rammstein wrote:Just be aware you will have to use 'V' as the construction method for beams, slabs, meshes, etc., now as well.
Now I've assigned C button to "Change flip status", and V button to "Switch Construction Methods".
2015-11-22 09:40 PM
Barry wrote:I know, thanks. Before ArchiCAD 19 I have worked with AC16 and C button I've always used only for flipping walls.Rammstein wrote:Just be aware you will have to use 'V' as the construction method for beams, slabs, meshes, etc., now as well.
