Labels
Brett Brown
Hi All, Is there any way of assigning a label description of different composites to walls, slabs,objects etc (then saved with favorites) so when in Section or Elevation you pick the wall etc you want to label and they appear with the different description of every different wall etc? Or is there a different way or work around to achieve the same end? Thanks
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
6 REPLIES 6
Erika Epstein
Have you checked out CADimage's Keynote system?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Brett Brown
Yes I do use it, but was hoping that this so called No 1 BIM program would have a way of doing this that I hadn't found. Obviously not.
Ben Cohen
Try the Wall Label 11. This label will show the skin names and thickness. It can also be used in section/elevation and floor plan.
Ben Cohen
Mac and PC
Archicad (Latest Version) aus
www.4DLibrary.com.au
Brett Brown
Yes I looked at that but is very limiting. From what I can see it names the thickness of wall and fill name and you can't turn them off. All I want is a text description (keynote) attached to the wall in the same way as above.Surely this wouldn't be difficult to do by GS and all options to be disabled or not.
Sam Wheatley
Not sure if this is what you want but the AC 11 label allows me to turn of text under Label selection settings/symbol label/text parameters ON or OFF , and the detail number can be saved as favorites with different numbers for different types
ArchiCad 26 US
IMac Pro
iMac 3.2 GHz Intel Core i5 16 GB
NIVIDIA GeForce GT 755M 1024 MB
You can get what you want from the Labels and good schedules to match them.
You can even have all of your rafters or other framing members labeled with the size and length of each one and put into a schedule.
You can even use labels to automatically number things for you like treads and risers, footings, what ever....
Labels are good.
