‎2007-12-07
10:29 AM
‎2023-05-25
06:31 PM
Rubia Torres
‎2007-12-07 12:18 PM
‎2007-12-07 04:19 PM
‎2007-12-07 06:28 PM
Thomas wrote:Yep that's nice.
drag-copies of the resulting level dimension
‎2007-12-07 09:57 PM
‎2007-12-07 11:31 PM
Thomas wrote:Well that's intuitive, not. I've only used that technique for meshes so I haven't been bitten by the roof thing.
What happens is that the Autotext (when copied) somehow reads the first level and recalculates for the new position using the extended plane/slope of the first roof and the distance from the first position.
‎2007-12-08 01:11 AM
‎2007-12-13 08:37 AM
Thomas wrote:
Well, not THAT happy anymore. i discovered that the drag-copy works within the area covered by one item (a mesh or a roof) but when you delve out of that, for example over another roof, it wont work. It displays the level as it would be had the first roof extended to the current place, instead of using gravity at the new position.
So if you use drag a copy on a level dimension, be careful. Check and double-check! When above another roof, you have to place a new dimension using gravity, and then edit like James described it.
‎2007-12-13 09:05 AM
TurboGlider wrote:I believe you're right, programmer-logic-wise. The problem with this surfaces when I copied a level dimension in the floor plan to a spot outside the "current" roof's polygon - there I got a displayed non-existent "virtual" reading to a non-existent "virtual" extension of the same roof's projected surface plane. Not very useful.
It's totally natural that level would behave like this, because it is connected to the roof that you place it on. If you don't make the software behave like this you could get enormous problems later, lets say you have alot of roofsobject on each other that represent inner roof, outer roof and so on, which roof should level object act with if you turn the other roof on??
‎2007-12-13 10:53 AM
